drop link advice
- westonwarrior
drop link advice
Just got some drop links and I am going to fit them tomorrow.
Now those that have already undertaken this task,
Did you need to support the roll bar or does it sit in place so to speak?
Any other advice?
I know about the wd40 and am going to do that now
Thanks in advance
Any other advice?
Thanks in advance
rear drop links are e talking about?  If so I had loads of excellent advice (on BF if you search).  Thecore of it was to make sure the van is 'sitting' as it would in normal use as otherwise you may tighten the drop links in the 'wrong' position and when the van is put back into its normal sitting position, the rubber bushes will be twisted by the load and split/give out prematurely.  In practice this seemed to mean I was OK having both wheels on axle stands with the wheels off so the van was level in the lateral plane (i.e. as seen from behind).  It didnt matter that its 'bum' was up in the air somewhat.  I asked and asked again about this and was reasssured it was fine.  So I tightened everything up on the stands, then let the van down to ground when done.  Only time will tell whether I've been 'naughty' but I dont think so.  Hope this helps.  Mike
- westonwarrior
				ebygum32
same as what mike said for the front did mine a couple of weeks ago, no problems some members used two jacks one to support the van and one to support the link, i just took the wheel off then used ?17 or 19mm socket and cursed as they were tight even had to get air impact wrench on one to get it off but start to finish just over an hour hope this helps
						- Simon Jones
- westonwarrior
Job was done this afternoon and surprisingly quickly
I jacked up both sides and rested axel stands under the wishbones so it rested as if it were in drive level.
Took one wheel off at a time just in case
The nuts were tight and I had to put a spanner on the back nut of one of them as is spun but once it started moving it undid very easy.
So job done in about an hour and no more clunk.
- brorabongo
				ebygum32
- westonwarrior
