Impact Wrench
Impact Wrench
Post by francophile1947 » Fri May 04, 2007 8:23 pm
Anybody know if those 12v Impact Wrenches are any good? - they've got some in Aldi for £15.99.
They look like electric drills and I would have thought that they give a heck of a twist to the wrist if the nuts are tight?
Peg leg Pete
Post by Peg leg Pete » Fri May 04, 2007 8:46 pm
There is a joke there waiting to be told :wink: not sure of the quality of wrench--- impact wrenches usually require a blow from a hammer, so not sure how an electrical version will do the same job :?:
Image Pete
etihsbog
Post by etihsbog » Fri May 04, 2007 8:55 pm
I have used these to remove locking wheel nuts off alloys, when I have lost the adaptor. If the heads are too small on normal bolts then they will round them off though, before using one a good soak with some releasing oil and using a standard socket might be a better option.
Post by francophile1947 » Fri May 04, 2007 9:26 pm
peter humphrey wrote:There is a joke there waiting to be told :wink: not sure of the quality of wrench--- impact wrenches usually require a blow from a hammer, so not sure how an electrical version will do the same job :?:
I think they're a bit like heavy duty hammer drills in their action - just never used one so wondered if anyone else had - could be useful for wheel nuts.
Post by francophile1947 » Fri May 04, 2007 9:28 pm
Hi etihsbog
I gather that they must have a fair bit of torque then - I've only use air-powered and "hit with a hammer" ones before.
Peg leg Pete
Post by Peg leg Pete » Fri May 04, 2007 9:29 pm
As long as the nuts are high tensile, which they should be for the wheels :wink:
Image Pete
ChrisEm
Post by ChrisEm » Fri May 04, 2007 9:30 pm
Impact wrenches do not work like a drill, there is very little force transmitted through to the wrists. Each 'impact' is absorbed by the nut or bolt you are trying to undo or fasten. I've used a couple of rechargeable good quality ones and some seriously heavy 1 inch drive air versions, not used the 12v ones but would imagine they're ok for fairly low torque applications. They're cheap enough if it's not up to much.
Post by francophile1947 » Fri May 04, 2007 9:36 pm
ChrisEm wrote:Impact wrenches do not work like a drill, there is very little force transmitted through to the wrists. Each 'impact' is absorbed by the nut or bolt you are trying to undo or fasten. I've used a couple of rechargeable good quality ones and some seriously heavy 1 inch drive air versions, not used the 12v ones but would imagine they're ok for fairly low torque applications. They're cheap enough if it's not up to much.
Precisely what I thought - perhaps I'll treat myself.
