Hi folks,
Can anyone help. I need to get the tracking checked on my new baby but the tyre co. need the data as they haven't got a Bongo listed.
Thanks in advance.
						Tracking
My Workshop Manual says this:
FRONT WHEEL ALIGNMENT
Steering Angles
-Inspection
Use a turning radius gauge to check the steering angle
Standard value Inner Side 39 degrees + or - 2 degrees
Outer side 35 degrees + or - 2 degrees
Would this be it? There's also stuff about camber and caster angles but I dont suppose that is what you need right now?
Hope this helps
Mike
Steering Angles
-Inspection
Hope this helps
Mike
				BennyBongo
Thanks for the info Mike but in my experience tyre depots only have the equipment (and mental capabilities) to measure the tracking eg. toe settings. The measurements you have are, I believe, used to set up the total steering and suspension geometry by people such as Main Dealers and Body Repair Shops.
				timhum
Check out "Wheel Data" in the fact sheets. It is all there. I took the sheets to the tyre shop when I needed a full set and they did the business.
The "Average toe in value" is given as -1.7 they understood that and the Bongo seems better after the adjustment.
The fact sheet gives all the instructions needed for an experienced tyre fitter.
He seemed to understand what was going on anyway. He seemed impressed that I had the info and took time to get it right.
My usual mechanic told me to ask for a "4 wheel" tracking check. That is the one when they put the mirrors in the back wheels and fire a laser down the side of the vehicle.
I know virtually nothing about all this but armed with the data sheet and the 4 wheel tracking advice, the tyre fitter realised I was not to be fobbed off and was very conscientious.
Hope this helps,
Tim
Hope this helps,
Tim
				BennyBongo
Tim
you've obviously got an intelligent tyre fitter where you are. I took my other car into a local company to have the front tyres swapped from side to side and the muppet let the jack down too quickly - result = suspension compressed and car stopped it's downward travel when it hit the jack. Cost them £1200 for the repair but as a good bit of P.R. they didn't charge me for swapping the tyres over.
				timhum
Yikes, at least they had the decency to put things right and give you the tyres.
I guess I had the muppet tendency on my mind when I mentioned going in complete with knowledge and jargon to show them you know what you are expecting.
I have had bad service in tyre fitting places before and found myself being fobbed off if it was the easy way out.
Another thing I forgot to add is to tell them to torque the wheelbolts to 110 foot pounds. I was not sure of the amount (someone will be along in a minute who knows the correct value) but it stops them making a roadside tyrechange impossible with their impact drivers.
Cheers,
Tim
Cheers,
Tim
