Post
by daveblueozzie » Sat May 12, 2007 6:35 pm
just this second replaced the brake side light bulb ,dead easy open rear door you will see two screws at side of the light cluster undscrew slide the whole unit out to the left or right depending which bulb has gone, middle bulb twist to undo and replace then put it all back the same way as you took it apart 5 min job
Lost without my Bongo.
