When the hold light flashes, the autobox is in default mode and will not hold or go into 4th gear. The reason is that the gearbox receives signals from the speed generator and when it doesnt get them it goes into default mode.john and jue wrote:hi bumbly1 when this happened to you and the hold light flashed did the hold button have any effect on the gearbox .mine doesnt when the hold light is flahing
   hI, THIS MAY HELP. a short while ago i had th ABS light coming on kicking in the ABS itself, posted the question on our fab site and was given the answer that it may be the connections at the back of the speedo duly took of speedo pod and pulled out the connectors gave all a wipe over and put back together and HEY PRESTO all ok. worth a try
