I feel a bit embarrassed about asking this 'tecky' question as, in a previous career/ life, I qualified as an electrical engineer.
I have a Bongo with standard 'peasants' air con and not the posh climate control.
I have searched the forum and the members sections but have not found any reference to removing the blower motor.
My fan blower is squealing like a porker on slower speeds. It is now a case of fixing the blower motor or buying two sets of ear defenders
In an attempt to lubricate the fan bearing I have stripped out the top ducting and gained access to the fan blades, removed the fan retaining nut but have been unable to remove the fan section.Trying devious ways of injecting WD40 below the fan has been unsuccessful
To access the motor it now looks like a strip down of the bottom ducting housing? This looks a bit more heroic than the 'simple half hour job' described in several forum items.
The schematic diagram, in the members section,seems to indicate the fan might be retained by a screw set underneath the housing and that it
might drop out from under the housing??
Any advice about how to remove and repair or replace the 'noisy blighter' would be appreciated. Her Indoors is threatening not to venture out in the Bongo until it is fixed! On second thoughts, maybe I should buy one set of ear defenders and leave the fan as it is?
Prior to setting to and ripping the ducting apart I thought a line (??) to the old hands might save me 'swearing and sweating' time!
I grovel at the feet of the experts in hopeful anticipation
