I have just managed to source what I have bee told are original bongo 15" alloys to replace the standard  steels that I have .  Am I right in assuming that i will need different size nuts and if can anyone let me know what size i need to buy?
						Wheel Nuts
				KeithB
				KeithB
As Keefy suggested, try e=bay ( about a£1 each ) keith b.
They will need to be replaced anyway,as the nuts used on the steel wheels are not compatable with the alloy wheels.
After a while, you will find the steel wheel nuts will bond to alloys,making them near impossible to shift. (even with copperslip)
In addition,you may find the opposite is also true,where you need to keep on re-tightening the steel nuts to the alloys... If this scenario occurs,then the mating face of the nuts differ to the flange on the wheel.
I think, (dont quote me) the mating face is a 60 degree angle with mazda alloys.
				KeithB
Excellent!... glad they could be of assistance to you!
I've got to the stage now, where i dont bother with main dealers,at all for anything. You are lucky that you have built up a rappor with your dealer,i, however didn't have the patience I,m glad you did
  I,m glad you did
 I,m glad you did
  I,m glad you did
