valve clearances
- dreamwarrioruk
valve clearances
hi can anyone tell me the van clearances for a 95 aft 2.5 wlt engine
						I thought I'd read somewehere that the valves were hydraulic, so no need to adjust.
									1995 N reg 2WD AFT in green/grey
www.whiteroseancestry.co.uk
- dreamwarrioruk
You are probably right,  it was this thread from last year which I had read.  http://www.igmaynard.co.uk/bongo/forum/ ... ht=tappets
There seems to be some confusion as to whether they are hydraulic or not.
Need someone with a workshop manual to confirm.
Per the WLT Engine Manual CD, the clearances are (cold engine):-
Inlet 0.05 - 0.15mm
Exhaust 0.15 - 0.25mm
Don't know why there is such a large range in the clearances
													Inlet 0.05 - 0.15mm
					Last edited by francophile1947 on Sat Jul 07, 2007 9:21 pm, edited 1 time in total.
				lez
				Vanmanerik
Valves
Franco says, 'Don't know why there is such a large range in the clearances' - the exhaust valve gets hotter therefore expands more.   It lets HOT gasses out, the inlet valve lets COLD air in.
 It lets HOT gasses out, the inlet valve lets COLD air in.-
Didn't mean that vanmanerik - I wondered why each valve had a margin. In the old days, the gap always seemed to be a set measurement i.e. 8 thou.
As you say, exhaust valves have always had a larger gap due to the heat.
				Vanmanerik
Valves
Now if the topic was in thous, instead of this metric nonsense I would have understood the question.  I can 'feel' to a couple of thou but what is 0.15mm - might as well be green cheese!
   I can 'feel' to a couple of thou but what is 0.15mm - might as well be green cheese!-
Re: Valves
I know the feeling - it used to be the thickness of a fag packet to set the pointsVanmanerik wrote:Now if the topic was in thous, instead of this metric nonsense I would have understood the question.I can 'feel' to a couple of thou but what is 0.15mm - might as well be green cheese!
