Heater plug warning light flashing
hurricane
My heater plug warning lamp has started flashing continuously. The engine starts fine so I don,t think there is a fault with the plugs. The drivers manual refers to this lamp coming on if there is a fault with the cooling fans but I have no cooling problems. Does anyone know why this lamp should flash.
clogger
do not know if it is any way related to your problem
i recently put a leisure battery in mine and hardwired it into fuses
1 and 8 the internal gubbins and rear lighter output for permanent live
i started the engine without rejoining the 2 wires the engine started but the heater plug light flashed until i rewired power to them
long winded but try the fuses top left and right in the fusebox under the steering wheel
worth a shot
worth a shot
ECKY THUMP
the one true art form
