Can someone tell me where the atf drain pan is? Preferabley a diagram or photo. I also need to know the type of sealant to use for the gasket. I have read the fact sheet on changing atf.
Changin ATF
Crazy Legs Crane
- westonwarrior
Crazy Legs Crane
Didn't word very well
Sorry, I meant the sump pan. The description does not match what I see. Do you have to remove the plastic underneath to see it?
ChrisEm
see here! This is what it looks like
http://www.igmaynard.co.uk/bongo/forum/ ... ht=#102665
You do not need to take the undertray off as the gearbox sump is to the rear of this.!
. You should not find it necessary to have to replace the gasket.
