now, should i -
a) try and remove some down to below the FULL line, if so how?
b) leave it. as it expands, will the excess come out the breather pipe or overflow or whatever it is?
thanks chaps and chapettes
No haden is correct, if you take the filler cap off the expansion bottle and then the one off the top of the rad it drains the expansion bottle.flippa wrote:hello spit i hope your not stood their waiting for the water to jump out of the rad cap
hadyn probably means the.. radiator drain plug ..bottom left just a trickle then you can keep an eye on the level till your happy
