opinion on buying slightly oily van ***DON'T DELETE***
tattoodaisy
- Bongonaut
Hi All,
First post as potential bongo owner.
I went to view a bongo to buy and as I don't know much about engines took some photos to show my dad -he didn't like the look of the oil and the fact that it did drip a few spots of fresh oil on the road after a short drive. Could I ask those of you who have some experience to look at my photos too. The rest of the van is in pretty good condition -it's done about 69,000m and is a turbo diesel 2.5.
The bongo owner took it to her garage and they said engines of that age are expected to leak a little oil. She has kindly agreed to get another opinion tomorrow but we'd appreciate some unbiased opinions from the forum too.
(pics no longer available).
Thank you.
Daisy
Thank you.
Daisy
Think Id err on the side of caution tattoodaisy!! I too dont like the look of that oil and if its dripping there must be a fair bit.Had mine 12 mths and not a drip so Id just be carefull.You could always have a vehicle report done on it but its only worth the cost if you really are keen on it.There are plenty of others about so dont jump at the first one,its just a concern looking at the slick and its position underneath.
Im sure others will chip in!!
Good Luck and Welcome to the Forum
Dabs
Dabs
BongoJim
I would hate for you to dismiss a good car, But I would hate even more if you got a bad one.
It's really difficult to give an honest view with out looking at the car and from two photographs very difficult to diagnose a problem. Could be as simple as the oil filter not tightened and leaks under pressure or it could be much more expensive. Mine doesn't leak a drop.
As Dabongo said there are plenty of other cars around, but if your keen get a report I think the AA or RAC will do it for a fee. Ask someone to go with you who does know about car engines usually for the cost of a few pints.
But go with gut feeling, if you have to ask. You already know the answer.
BongoJim
BongoJim
I agree that old engines can seep a little oil (mine has a small leak from the rocker cover), but that seems very excessive.
Also, the top picture is the rear axle - not clear where leak is from (could just be level bolt) but it's not the sort of thing you check often.
- westonwarrior
It could be as simple as the filter on the other hand it could be very expensive.
there does seam to be alot of oil I would recomend an inspection by the aa /rac or you take it to am independent garage and find where its coming from, as to my untraind eye it looks more like a spray of oil than a drip.
Can they supply a milage certificate or import docs to support the milage/
does the inside look ok, seats comfy and not flat and worn.
Is it a reasonable price , if its cheap you can allow a repair in the equation.
If its very cheap why?
Mostly what was your gut feeling If your not confident walk away
- westonwarrior
Naughtydog
Dont listen to the sales patter, that they are flying out the shops, there are plenty around, so take your time. trust your gut. I doubt i would buy it, but i would be just as careful with one that is gleaming. the bongo is usually around 8+ years old, you would expect some oil around it.
but one that is dripping oil i would suggest that your buying someone else's problem.
as a rule of thumb, any item on a car that requires oil, should never loose its contents, unless there is something wrong.
ChrisEm
tattoodaisy
- Bongonaut
Thank you chaps
Just go to show that dads are often right !
But we don't always want to believe them. I'll keep looking and hopefully join you all on the road soon.
spe llink d*ue to Kirsty's sloe Brndy!
dp bradford
- maxheadroom
- westonwarrior
tattoodaisy
- Bongonaut
Two garages said they couldn't find anything wrong -so the owner has had the underneath steamed and taken it to a third garage, they said that the oil filter hadn't been tightened up,they are going to replace it and she's going to send me some more photos.
I was just wondering what DP meant about multiple problems.
I will get a proper check done before I offer any money.
The van is in Portsmouth if anyone wants to take a glance at it for a couple of drinks -just to see if it's still dripping.
