Safety Device for a trailer
- AndAndDen
What sort of Safety Device will i need for a Erde 101 Trailer just in case it comes unhitched
while driving the Bongo. Thanks
Get a Life ,Get a Bongo. !!!
rob and karen
Colin Lambert
dp bradford
- Peg leg Pete
rob and karen
the secondary coupling cable is ideal
that is attached to the front end of trailer and put around the towball , the same as a break away cable , if you had a brake away cable you have a bracket which attaches to the handbrake on caravan/trailer ,then wrapped around the towball , so yes a secondary coupling cable is what i would put on
rob
rob
Bonza
flash
- daveblueozzie
my erde trailer came with a short chain attached to it i hook it to the tow bar using a padlock for a bit extra security so no one can just unhitch and walk off with the trailer, i know any determined thief would laugh at the padlock (but it does deter the kids out for a bit of fun at my expense).
Lost without my Bongo.
- dreamwarrioruk
on our towbar ive put a secondary breakaway plate for securing the cable to, i dont really trust just looping it over the towball.
plus i believe this act is now illegal
http://www.towsure.com/product/479-Brea ... le_Bracket[/u]
Harry
I think that you will find that 'breakaway cables' are what is fitted to breaked trailers. They are attatched to a device on the trailer handbrake wihich trips a catch and puts the trailer handbrake on if the trailer breaks away from the towing vehicle...I had one of these on me big box trailer I used to use for shows.
The little Erde type trailers are unbraked and don't actually require a breakaway device.
Sticking the chain around the towbar is more psychol;ogical than of any real benefit...but I do it anyway...and its not illegal (I've checked).
cheers
H
cheers
H
Pete
