Can anyone tell me if there is a seperate fuse for the rear wiper. Mine just stoped working, all the fuses by the stearing colum are fine. I took the back door apart to check wiring, I have no power to wiper motor, hope its something simple,
Can anyone help Please
Rear Wiper
Hny
Lovejoy
You didn't just instal some rear curtains too did you ? I did recently and my rear wiper stopped working - cause I drilled through a cable.
As far as I know, the only fuse for the rear wiper is the red 10 amp one in the middle row of fuses next to the steering wheel. Might be worth swapping it for the horn fuse (directly above it, also 10 amp) just to make sure the fuse is OK.
Hny
