hello fellow bongoers,
my little bongo's airbag light recently started to flash (6 then pause). I was hoping for some advice as to;
i) undertsand what it means
ii) stop it flashing
i think it started when i slipped the bongo into a low gear setting by mistake whilst on the move.
many thanks in advance.
rhubarb
flashing airbag light!
rhubarb
Colin Lambert
smartmonkey
Bongeezer
rhubarb
thanks for all the suggestions, i did put water in (which worked for an hour or so), oil in just in case, also moved seats back and forth which did not work. i will try and locate the seat sensors and give them a wiggle to see if that works and let you guys know if it does the trick.
thanks and please keep more suggestions/theories coming.
rhubarb
rhubarb
pippin
