This is to help others if the same occurs;
This week my stereo decided to work intermittenly, then my indicators started fading and then failed altogether, then my remote central locking only worked on drivers door leaving all others insecure, then my interior lights didn't work either..............worst of all, the glow plug coil light started flashing at me!!
I thought my Bongo was doomed, all that in one week. I checked all the fuses under dash - ok, gave the indicator flasher unit a wiggle, cleaned the temp sensor near handbrake (from bongo clinic), no change.
Then I discovered a blown fuse in my leisure battery split relay kit - my leisure batt was unable to charge. One new fuse and its all working again brilliantly.
The wiring kit was from madmile125 (ebay ID), this is no way a bad reflection on his product, it works superbly and easy to install. But thought i'd share this experience in case you have same wiring set up!!
Electric drama
bongomountainbiker
- daveblueozzie
we had the same problem with bigdaddycains at the charity farm meet ,we borrowed a multi meter from trevd and found leisure battery not charging ,checked the fuse ,not blown but smashed, the bonnet must have hit it where I MYSELF PUT THE BLOODY THING, new fuse and moved to a safer place all ok.
Lost without my Bongo.
