starting problem - call for opinions
				bongalong
hello,
just went to start el bongo and nothing happens. ran him fine the other day.
symptoms:
put key in ignition, turn, everything normal. orange glow light on, then off, array of red lights as per usual.
turn key to ignition and all i get is a single click sound. not even a single crank of the engine.
it appears that the electrics are ok and behaving normally
i am thinking either:
- blown fuse
- starter motor
- alternator maybe?
does any one have any ideas where to start? or the best way to track down the problem?
there goes my sunday of relaxation.........
thanks in advance
symptoms:
- blown fuse
- starter motor
- alternator maybe?
thanks in advance
				trevd01
				platty345
				harpo42
If you are getting a click sound then i would say its the solenoid. This is the small round device attached to the starter motor.
On the end of the solenoid are two terminals one goes to the battery via a heavy duty cable the other is a short cable that goes to the starter motor.
if you can try shorting them together. BE VERY CAREFULL
  If the starter turns (It wont engage and turn the engine) then your starter is ok but your solenoid is kaput. If you get sparkes on the terminals  and nothing else then your starter is jammed.
				Ralph
				bongalong
				moonshine
Sounds like the solenoid to me too.  I had this problem myself a while back.  Turn the key... click..nothing.  Turn it again, click...still nothing.  Turn it one more time and it starts normally.  Sometimes it took two goes, sometimes ten, sometimes it would start straight away.  Took the starter motor off, replaced the contacts, put the starter back.  Whole job took about an hour, and cost about £16 for parts.  Starts beautifully now.
				bongalong
				Biddy
Are your battery terminal connections tight enough ??
This happened to me and I thought OH NO! starter motor, then my neighbour said silly you had a new one when you bought your Bongo but we changed our battery last year......... Dave checked the terminal connections and they were loose...... so far so good......... starts every time (touch wood)
				bongalong
thanks Biddy, i will check. I did install the low coolant kit a few weeks ago....Biddy wrote:Are your battery terminal connections tight enough ??
This happened to me and I thought OH NO! starter motor, then my neighbour said silly you had a new one when you bought your Bongo but we changed our battery last year......... Dave checked the terminal connections and they were loose...... so far so good......... starts every time (touch wood)![]()
				rob and karen
my neighbour has recently got a bongo , and he suffered the same problem you are getting , all i did was disconnect the battery first  drop the starter out 3 bolts used a bit of wd40 to spray the dog end and the solinoid i gave a few small taps , put it all back together and hes had no trouble for 3 weeks now starts first time every time ,
hope this helps
rob and karen
						hope this helps
rob and karen
				Mikey B
Clicking sound
When this happened to me a while ago it turned out to be the starting motor. Had it replaced locally in Llanelli (reconditioned unit) havnt had the problem since.
Some days it would be fine, no problems then other days it would "click".
Before having the starting motor done, I used to give it a little tap with a small hammer whenever it "clicked" to release the contacts - would start straight away then. A bit of a pain to do especially in the supermarket as I had to remove centre consol, lift seat, then give the starting motor a tap. But this method did not leave me stranded with a boot full of groceries.
