Head Bolts
Gordon
Head Bolts
Could someone please tell me the correct torque for a 2.5TD head bolts. Ta
BongoNess
Dannyboy
Gordon,
The sixteen main bolts should be tightened to 29Nm, then after marking with tippex or something similar, they should be tightened through a further 90-105 degrees, then again through a further 90-105 degrees. I only did then through 90 degrees each time.
The two small bolts at the front wil strip at this torque and should be tightened to only 19Nm.
I am sure this is covered in a very good fact sheet, I think by Declan Hicks.
Good luck,
Dan
Good luck,
Dan
- dandywarhol
