Replacement speedo dial
Responder59
Post by Responder59 » Sat Oct 20, 2007 12:18 pm
I,ve just received a MPH replacement dial for my Bongo.
I can,t find a thread with fitting advice so I wonder if a kind BONGOTECH could talk me through the procedure please.
regards,
N415 PTL
Post by Doone » Sat Oct 20, 2007 1:07 pm
This is metioned a few times on the forum. If you read all the way through the topic on this link, it should sort you out.
http://www.igmaynard.co.uk/bongo/forum/ ... d1c2#73540
brorabongo
Post by brorabongo » Sat Oct 20, 2007 4:06 pm
Would they be the same to fit as these?
http://www.igmaynard.co.uk/bongo/forum/ ... hp?t=14641
as they are easy enough to fit, without removing the needles 8-[
ボンゴの激怒 pictures
Responder59
Post by Responder59 » Sat Oct 20, 2007 4:48 pm
Thanks for the info so far,BUT, what I need are step by step instructions
starting with "Pick up the Phillips scredriver"!!
If it will break I will break it!!
In eager anticipation,
Steve
tridentlee
Post by tridentlee » Sat Oct 20, 2007 5:36 pm
where abouts are you steve, if you are local to me in kent, i can show you how, i did mine a while ago and its quite simple, you havent put your location in your profile, lee
Responder59
replacing speedometer dial
Post by Responder59 » Sat Oct 20, 2007 6:19 pm
Thanks for the offer Lee,but I live in St Ives Cornwall!
tridentlee
Post by tridentlee » Sat Oct 20, 2007 6:22 pm
ah, a liitle to far for me or you to travel, just take your time with the job its a little tricky but you will be fine, treat it like a woman, gentle, then if all else fails BEAT THE CRAP OUT OF IT, lee
jetwashjimmy
Post by jetwashjimmy » Sun Oct 21, 2007 10:48 am
Why didnt I read this post yesterday...doh fitted it all together in the house put it all back turned on the ignition and nought to 20 in 0 sec...bugger
so then tried with it in place, pulled centre cap of needle and the soddin counter weights dropped behind the facia, retrieved these and dropped one down the side of the drivers seat, neccesitating removal of the seat.
apart from that and pulling the wire out of the rear fog light spade, a doddle....havent tried it yet though, could be :oops: .
