This forum is brilliant, so quick and helpful, a big THANK YOU to everyone
  The problem is a starting one listed under "my mechanik is at a loss" below.  Well, he has checked the relay and it works but he thinks that the glow plugs are blowing because they get 12volts to them and should only be getting 10volts, therefore he is looking for a faulty 'voltage regulator'. Is the system that voltage critical? and where would that regulator be?
Thanks again
Michael
