I have a nasty suspicion that I have a failed bearing on the rear wheel (s)
Does anyone know if the half shaft has to be removed to replace a
bearing and has anyone done this job themselves? - Why me Lord - I bin
good !
Rear wheel bearings
- dandywarhol
The half shaft does need to be removed having dismantled the brake assembly first. The bearing will need pressed off the shaft.
Best to replace the oil and dust seals at the same time - the oil seal is separate from the bearing and located in the axle casing.
Thanks to lushprojects again for the diagram
http://www.lushprojects.com/bongoparts/ ... 0axle.html
ebygum32
