LIDL'S oil sucker
Colin Lambert
LIDL'S oil sucker
to overview
Product 2 From 23
http://www.lidl.co.uk/uk/home.nsf/pages ... mp_Set.ar3
Oil Pump Set
Suitable for oil, petrol and other liquids
Capacity (L): 1.5
Supplied with:
- Oil suction hose
- Adaptor hose
- Suction hose
- Plastic funnel
Price per set
4.99*
Only available while stocks last
Product 2 From 23
Oil Pump Set
Capacity (L): 1.5
Supplied with:
- Oil suction hose
- Adaptor hose
- Suction hose
- Plastic funnel
Price per set
4.99*
- daveblueozzie
Got one & it works sucking up water into a 5 litre container, the pump bit sits in a conical rubber collar thing that sits in the neck of the vessel being used, creating a vacuum as you pump. There were only about 10 in Weymouth & I was the 2nd person there as the door opened.
Blimey, Kirsty - you were lucky - the one I got there today will only will hold 1 1/2 litres.missfixit70 wrote:Got one & it works sucking up water into a 5 litre container, the pump bit sits in a conical rubber collar thing that sits in the neck of the vessel being used, creating a vacuum as you pump. There were only about 10 in Weymouth & I was the 2nd person there as the door opened.
Mike
Curator of the Bridgwater Motorbike Collection
- dandywarhol
I had the same thoughts as you Yammy when I looked at the last on in Edinburgh's branch and dismised it as being too small but missfixit's smarter than most
- it'll fit any sized container with a neck size up about 30mm. I read her post and immediately rushed back - it was still there
- dandywarhol
ford tinny
ford tinny
- dandywarhol
