Solar panels: efficiency and wiring...
neilfraser
I see Maplins have their 13 Watt solar panel briefcase on special until the end of the week, which makes it £50.
Now 13 Watts doesn't sound like a lot, but if you adjust the angle and position it may be possible to increase it's effective rating by a factor of 5 if you believe what the manufacturers claim about this panel:
http://www.outdoorbits.com/alden-sunpow ... p-272.html
If so it would be worth a buy, especially as it includes a regulator.
We have a converted Bongo with Zig and leisure battery. Could I wire the regulator directly to the leisure battery terminals without upsetting the Zig charging mechanisms?
Any electrical experts out there?
- dandywarhol
Mine was a 12W panel until I recently sat on it when fitting the roofbox
To be honest Ithought it was too little to do much good - at less than an amp at source by the time it got to the front mounted leisure battery any gain was soon lost if an appliance was switched on.
The link leads to a 100W panel that never achieves it's maximum potential of 8.5A (max achieved 5.9A). It would therefore seem that a 13W panel is unlikely to achieve it's potential of just over 1A - fine for trickle charging the batteries, when no power is being used, but not much use for boosting the available power.
neilfraser
My point was more along the lines of, if pointing at the sun directly throughout the day can increase the utilisation of the panel by a factor of 5, then this is going to be as useful as a 60W panel on the roof, is it not?
I would be using to supplement a 85 AHr leisure battery.
Just out of interest does anyone know how far you would have to drive to get the equivalent charge e.g. 8 Amps?
Neil
Neil
That's not the way I read it. They are saying that, by aiming it at the sun, you will get nearer it's maximum output. So a 13W panel may get near to 13W IF it is aimed at the sun all day - it cannot exceed it's maximum power output.neilfraser wrote:My point was more along the lines of, if pointing at the sun directly throughout the day can increase the utilisation of the panel by a factor of 5, then this is going to be as useful as a 60W panel on the roof, is it not?
Neil
- Peg leg Pete
- haydn callow
The Bongo alternator is rated (I think) at 80 amps.So in theory in one hours running it should put a max of 80 amps into your batteries. However it is not that simple. Alternators output is not 100% and what they do put out reduces as the battery charges and fills up. Also a alternator produces it's max at about 10,000 revs. In a vehicle they turn at about 2 x engine revs so around 5/6,000 revs.
If your battry is discharged to around 12 volts (pretty flat) I would guess it would take a couple of hours running to fill it up
The reason I know a little about this is my life living on a narrowboat. I had 90amp and 70amp anternators working together to charge a 500 amp hour bank of battries. We fitted oversize crank pullyes to turn them at 10,000 revs and fitted remote ameters so we could monitor what was going on. Even with a management system fitted the output of the alternators dropped after about 20 min running. The most we could put into the batteries was about 130 amps at start up and this soon reduced to around 70 amps.
Solar panels we found were a bit of a waste of money. Wind generators were not much better.
So if:
wind power doesn't work?
solar power doesn't work?
All my recycing actually goes to landfill? (allegedly)
wave power might work!? Just hope the tides don't give up!
and we're runnig out of renewable energy resources?
Anyone for nuclear power? No. Just the French?
Excuse me while i just disappear for some Bongo Green Kryptonite!
"Living the Dream"
Following from what Hayden said, you could max the output of your alternator by fitting a 'Sterling Battery to Battery Charger'. The self build motorcaravan club are always promoting these.
Never used one, and at £200 not likely to in a bongo, but they seem to work in a similar fashion to a voltage sensing relay, but fool the alternator into giving a max output for a longer period.
I love talking to narrowboat owners. On the subject of windpower they reminded me that i general canals weren't a good environment for wind generation as they were too often shielded from directional wind. Some of the places Bongo visit might be much more suitable I think. I'm tempted to look into it along with all the other futile experiments I can't resist trying out
andyfb78
Just a bit of info on solar panels..... my thing....
The 'nameplate' rating of a solar panel is tkaen when the panel is tested at standard test conditions NOT real sunlight.
this is at 25deg C and 1000 W/sqm irradiance (light power), and perpendicular to the panel. it is very difficult to achieve this in reality as the sun is not likely to be at 1000 W/sqm and if it is, the temperature of the cells will be above 25 deg.
unfortunately, as temp increases efficiency falls.
the rating for the panel is likely to be VERY inaccurate for real conditions, and as yet there is no 'real' standard to allow analogy to the real world, they simply have to be tested......
you will therefore probably get significantly less power than the rated power in reality....
one thing this does mean though is that a particular cell is likely to produce similar levels of power here in less sun but lower temps, as it does in arizona at higher sun power but at detrimental higher temperatures.......
The angle of the panel makes a massive difference, the ideal angle for battery charging will vary, but assume due south, at an angle to the horizontal equivalent to the latitude (53degs ish for the UK). if the panel is immovable and to be used all year then increase this by 10 degs. Ie steeper, this trades some loss in summer for some gain in winter.
if it is movable then just under the latitude will give the best results. and if it can track the sun through the sky even better.
you will not get better than the rated power as this is at the perfect perpendicular angle, (ie all the light hits the panel).
Hope this makes sense...
Andy
Andy
Pete
