Trouble Starting and Black Smoke, lots of it!
Will Slatcher
For some time now, over the winter anyway our Bongo has been a little difficult to start. I now need to get this sorted else I'm gonna kill the starter motor which has to run over time for it to start.
Does this mean the glowplugs needs replacing?
Also if i blank the EGR will this stop all the black smoke on statup?
Will
Will
Will Slatcher
- mister munkey
Glowplugs for sure but maybe only one or two. . . .
The black smoke is the unburnt fuel from the weak pot/pots.
My local Ford Truck dealer quoted me £58 + Vat EACH for genuine Ranger plugs.
I'm sure you can do better than that though.
- mister munkey
Maybe a grown up would get a better deal.
- brorabongo
I had 4 new glow plugs sourced from Ebay fitted.Two went faulty after one week.
Then fitted 4 new ones from the Bongo shop no problems since.
cheapest not always best!
- brorabongo
Member dandywarhol would suggest NGK Y701J. I for one, will be buying them next time round.
Bear in mind that there are two lengths of plugs, so check which ones you need.
here you might get some idea
Glow plug thread
Glow plug thread
Will Slatcher
You have to take them out and short them across a battery (centre contact to body), just don't hold the business end when you do it.Will Slatcher wrote:Thanks for the info everyone, great help!
I will probably replace the lot with the NGK ones but if i was to replace just the faulty ones, how would you know which was good and which was bad?
If they glow RED they should be OK.
It really is best to replace the whole set while you are at it though.
I have had lumpy starting and lots of smoke since shortly after we got our bongo last November. Suspected one dead glowplug so........
Last Sunday got at 'em based on the fact sheet info for access and after removing the rail/bus checked each one with a multimeter for resistance and determined that no. 2 (from the front) was the dead one.
Bongo shop (thanks Ian amd Mariane for quick service and telephone response to the voltage query)supplied new plugs - fitted this morning and what a lovely smooth starting machine now
Now to tackle droplinks etc to stop the clunk going over speed bumps when I have plucket up the courage. Though the clunk only seems to be there when the vehicle is cold (just starting down our road).
