because the last 2 garages have seemed reluctant to have a look through not really knowing about bongos so i am pinning my hopes on the people in the know
Ps please tell me its not a very expensive job
Don't know what NE stands for. What it does is to measure the RPM of the engine. A few people here have had problems with faulty rev counters caused by a defective NE sensor.
I suspect its a coil that gives a little pulse each time some marker on the crank shaft goes past.
This one?corblimey wrote:Hi Kevo
There's a good picture from under the drivers seat on the cooling thread at the moment. Forth post from the bottom, page 4. You can clearly see the TPS. It's a black disk with 466 AT3 stamped on it.
http://www.igmaynard.co.uk/bongo/forum/ ... c&start=45
