Losing water .......OMG Its Hot
chrisd2211
Hi there I have an issue with overheating only just started, there was a lot of COLD water spewing from underside of van (Drivers Side around underside mid engine). When I removed Rad cap more pressurised cold water came spewing out which i thought was odd for a over heating van (By the way the fans were running) having had a quick look under I can see NO damaged or split pipes which leads me to believe that perhaps the water pump may have gone but not knowing or able to see the water pump I cant be sure can someone help please !! firstly where is the pump?? and secondly any other assistance would be appreciated. Thanks Chris. ( I knew I should have gone to College)
Re: Losing water .......OMG Its Hot
If it's pressurised when cold, it sounds like the dreaded head gasket has gone - has it actually overheated at some time? Doubtless somebody with more knowledge than me will post.
- maxheadroom
chrisd2211,
water pump is right at the front of the engine behind the top pulley. If it's that that is leaking water will run down the front of the engine. Head gasket should not leak water from the out side of the engine.
Agreed, but would a leaking water pump pressurise the system?maxheadroom wrote:chrisd2211,
chrisd2211
francophile1947 wrote:Agreed, but would a leaking water pump pressurise the system?maxheadroom wrote:chrisd2211,
is it possible it could be the thermostat not opening/closing properly?? To the best of my knowledge it hasnt happened b4
There are only three ways to pressurise the system.
By pumping gas in from the engine, which means a crack or a gasket gone,
By heating air up in the system - the usual method,
By water boiling somewhere in the system.
If the water pump was gone, then water would boil in the head and the radiator could still be cold.
If the stat was stuck the top of the radiator should still be hot.
There may be other reasons too. I'd check the pump first.
Dave
Dave
chrisd2211
ok heres a bit more info if I squeeze and release the water pipe in fornt of the alternator there is a clicking noise which is coming from a part that is mounted directly behind the dipstick would i be right in thinking that is the thermostat also having inspected the water on the road it is fairly clean the water puddle was just in line with the back of engine/gearbox, the radiator is stone cold if thats any indication. regards Chrisd2211
- The Great Pretender
Have you checked that the head is free of air?chrisd2211 wrote:ok heres a bit more info if I squeeze and release the water pipe in fornt of the alternator there is a clicking noise which is coming from a part that is mounted directly behind the dipstick would i be right in thinking that is the thermostat also having inspected the water on the road it is fairly clean the water puddle was just in line with the back of engine/gearbox, the radiator is stone cold if thats any indication. regards Chrisd2211
To infinity and beyond
chrisd2211
dont wanna seem thick
How do i check the head for air??? thanks
Just been re-reading your original post. Did you remove the radiator cap or the expansion tank cap when the cold water gushed out?
Is water still leaking?
if it is (i dont have a bongo yet) then this might be the valve in the thermostat - I was reading though a huge overheating thread on here somewhere, which tells of a small valve in the 'stat, which is there to allow air to rise up the system when bleeding, etc, but which closes when water trys to move through the opposite direction. Someone said they could hear this clicking when manipulating the pipe.chrisd2211 wrote:ok heres a bit more info if I squeeze and release the water pipe in fornt of the alternator there is a clicking noise which is coming from a part that is mounted directly behind the dipstick would i be right in thinking that is the thermostat
Dont think this would indicate the correct operation, or otherwise, of the 'stat (though, you could take it out and submerge in hot water (82oC+) to see if it operates as expected.
chrisd2211
it was the expansion tank cap i removed not radiator, do you think it could be the stat valve??
I was hoping it was the rad cap, as mentioned in your earlier post, cos' the water would have gushed out from there without pressure in the system.
Can't see how it could be the stat valve - that's just a small "pin" that keeps a hole open to let the air through when bleeding the system.
If you pm me I will talk you through it.chrisd2211 wrote:dont wanna seem thickHow do i check the head for air??? thanks
chrisd2211
More info.......Having just looked further I have found a split hose (the one over starter motor) but there is an underlying problem I think ........The top radiator hose warms up with engine running as is the water in the rad but the bttm rad hose is stone cold as is the water in the header tank also passenger side there are two metal pipes clamped to the chassis which I think are heating pipes one again is stone cold the top one warms up but this could be normal right ?? I dont think I have cooked the head as the water in rad is a clear rusty brown if that makes sense . I hope this helps.
Regards Chrisd2211
Regards Chrisd2211
