Hi gang
Just replaced my fuel filter.  Now the bongo won't start.  It turns over but won't start.
Now with the new  filter came two little rubber rings but when removing the old one there were no little rubber rings so I didn't think I needed them could this be the problem.  Obviously the big in built rubber ring was in the filter.  What are the little one for?
Please help.
						Won't start after replacing fuel filter
Re: Won't start after replacing fuel filter
It will take a long time to start until the filter has filled with fuel. I can't remember any small rings with mine, but my memory ain't what it used to be
There may be a primer on top of your fuel pump, if so, use that to get the fuel through.
hmm it still wont start.  Cant see a primer anywhere.  Scared of loosing batter power now.
phew
Took the filter off and added one of the little rubber rings to the bit it screws onto.
Its started yey.
I feel silly
Whats the 2nd one for?
Its started yey.
I feel silly
				Veg_Ian
One top between filter and housing and one bottom of the filter between sender unit if I remember correctly. Without them the pump will draw air into the fuel lines and hence it won't start. I don't understand how your previous filter didn't have them. Were they left behind on the housing or dropped off somewhere?
