cheap roof bars
cheap roof bars
Just bought a set of "value roof bars" from Halfords, £54.00, they fit a treat. You don't need a "fitting kit", just the roof bars and feet which all come in the one box, then drill out the middle outside hole on each foot to 8mm and bolt to the existing holes in the Bongo roof (bolts not supplied). Cheap and effective !
Re: cheap roof bars
Oops, forgot, they are called "401 value roof bars", in a red box.
Re: cheap roof bars
That's an excellent tip Brookie
Re: cheap roof bars
And another thing!! Fit the plastic feet to the bottom and drill through the metal and the plastic, fit the complete foot to the roof with the 8mm bolts, but use a couple of washers to make sure you don't over tighten the AFT roof nuts ! (thanks dandywarhol for the tip!!).
