hi all,
i cannot seem to locate a rear wash wipe reservoir.the rear has never worked,and i wasn`t sure if it had its own reservoir,or just a blocked pipe.
many thanks
jamie
rear waher fluid reservoir?
- hogggman
Re: rear waher fluid reservoir?
that was supposed to say`washer`,not`waher`,but i`m sure you guessed anyway.
thanks
jamie
thanks
jamie
The resevior under the bonnet does both ,i think
Brian
Brian
- hogggman
hi,
thanks,in that case,i have a blocked pipe or else the rear pipe is higher and my reservoir is low.will go and check.
thanks
jamie
thanks
jamie
yep, the rear one is higher & runs out first, one of them is hidden between the bottle & the front grille if you can't see 2 pumps.
