Suggestions please
kevo
Suggestions please
Decided to have a go and check the fuel strainer(banjo filter). I followed the instructions from
the fact sheet word for word.Having put it all back together the bongo keeps cutting out and
there is smoke coming from the exhaust. Does anybody have any suggestions has to why this
happening.
kev
happening.
kev
- westonwarrior
Re: Suggestions please
was it smoking before?
What made you check the filter?
kevo
Wasnt smoking before. I was just pottering about and come across it in the fact sheets
and thought i would have a go, didnt think it would do any harm, could the cutting out be a
fuel starvation thing.
Ralph
Something you took off is not seating/sealing/loose and letting air in ????
I was just going to say that
Veg_Ian
Did you note the order in which the washers went and replaced them in the same order? You maybe creating a blockage by not having the fuel inlet orifice at the correct height as a result.
kevo
Thanks all i will go over everything again.
kevo
If it is an air lock what can i do to solve it.
If it is an air lock due to changing the filter, see daveblueozzie's answer in the link above.
kevo
This has stemmed from me cleaning the banjo filter. since putting it back together it keeps cutting out, it will tick over nicely for about two minutes,then it starts juddering a bit
then a couple of puffs of white smoke then it just stops. can anyone shed any light please.
- dandywarhol
Like has been said before - sounds like its drawing air past the banjo washers. Did you replace or anneal them?
kevo
I know this sounds daft but i cant recall any washers where would they have been.
Its the first thing i have tried to do myself and i have made a right b*****ks of it
I will put it down as experience.
Bad luck on your problems
I shouldn't say this, but I will
If it aint broke dont fix it
Think I will check mine at the week end
F Zappa
F Zappa
- dandywarhol
Parts 24 - 0312 are the washers on this diagram
http://www.lushprojects.com/bongoparts/ ... esel).html
Veg_Ian
Kevo - if memory serves, there is a washer on either side of the banjo. Did you clean all surfaces and washers? Did you drop anything during dismantling? As has been said before it all needs to be clean and tight otherwise air can get drawn in. If it starts and runs for a couple of mins I don't think you have an airlock as it will already have been purged.
