Door Open warning light on... all doors closed
tipidave1
Post by tipidave1 » Wed Jul 02, 2008 10:05 pm
The title kind of says it all. The warning light is permenantly on, as though a door is open. Is this warning light used to signal anything other than a door open? If not, any ideas where to start tracing the fault?
daveblueozzie
Re: Door Open warning light on... all doors closed
Post by daveblueozzie » Thu Jul 03, 2008 8:04 am
Clean the contacts on the sliding door and the door pillar with a bit of emery cloth/sanding paper.that might help
Lost without my Bongo.
You've Been Bongod
Post by You've Been Bongod » Thu Jul 03, 2008 5:38 pm
check the rear door as mine does this and my door looks closed properly but isnt quite closed
you've been bongod
Post by Ian » Thu Jul 03, 2008 5:44 pm
It will be the wires behind the dash. Notoriously poorly insulated. Have you had your speedo changed recently? That's what usually causes it.
tipidave1
Post by tipidave1 » Thu Jul 03, 2008 6:38 pm
Thanks for the suggestions. A couple of new lines of enquiry... I will have a rootle around the speedo wiring... Does anyone know how to dismantle the rear door catch assembly in such a way as it will go back together again?
Post by bigdaddycain » Fri Jul 04, 2008 4:03 am
Do any of the interior lights illuminate,(in courtesy mode) even though the doors are properly closed?
tipidave1
Post by tipidave1 » Sun Jul 06, 2008 9:06 pm
No, none of the interior lights are on.
