speedo readings
lesamos
speedo readings
My Bongo speedo reads in miles per hour. Is it possible to get a sticker with Km per hour for motoring abroad?
Re: speedo readings
It's easy to remember the important ones
Roughly
31 = 50
40 = 65
50 = 80
62 = 100
70 = 110
80 = 130
Roughly
31 = 50
40 = 65
50 = 80
62 = 100
70 = 110
80 = 130
terminallybewildered
- Bongonaut
Re: speedo readings
I got a complete new dial on ebay (eg. item number 310065152925). It has both mph (outer ring) and kmph (inner ring). To fit, it does require dismantling of the instrument dial unit - a bit involved. I don't know of a simple stick-on solution, but you could convert mph to equivalent kmph and just have a post-it note with this info on next to the speedo. I did this before I fitted the mph disc. There are lots of conversion calculation sites on the web eg. http://www.militaryfactory.com/conversi ... to_kmh.asp .lesamos wrote:My Bongo speedo reads in miles per hour. Is it possible to get a sticker with Km per hour for motoring abroad?
Never drive faster than your angel can fly!
David Edwards
Re: speedo readings
I thought all speedos read in both, mph on the outer rim and kph inside, never seen one with just mph.
Re: speedo readings
KPH ones chipped to read in MPH and with an "MPH" sticker over "KPH" are, as there is obviously no need for dual KPH/MPH markings in Japan.David Edwards wrote:I thought all speedos read in both, mph on the outer rim and kph inside, never seen one with just mph.
