Stalling when warmed up
RobertandMarnie
Hello all,
We are Bongo virgins, having bought our bongo about a month go. We have had a problem with a stall when the engine has been warmed up; this can be after fifty miles or two hundred. It has not happened when cold or just started. We do not use veg oil (yet).
I have looked for leaks or signs of wear in fuel lines and cannot see anything. My biggest impediement is not kn owing what I am looking at, as we cannot afford to buy the manual yet.
Can anyone give me advice on what to tighten or loosen before I try to secure a second mortgage and have a fuel pump changed?
We have a burgundy, 1995 N reg 2.5 diesel. We are around Dartmoor next month if you want to say hello.
Veg_Ian
Re: Stalling when warmed up
Have you searched for similar problems reported on this site for ideas? Have you changed the fuel filter and cleaned the banjo filter yet? These are the first things you should try.
RobertandMarnie
there was a full service done including filter change three months ago.
where is the banjo filter?
I have not tried to take anything off yet.
Veg_Ian
The banjo filter is to the front of the fuel pump, driver's side of the engine. I was sure there was a picture of its location on here somewhere but I can't seem to find it. Unless someone else comes up with a pic in the interim, I'll try and take one tonight and post it.
Harry
If you put your location on your profile there may be an experienced local member who can help you out whith 'hands on'.
Certainly that's how it works in the North West.
good luck
H
good luck
H
RobertandMarnie
I did a search and found a picture of the banjo filter. Have taken this out and cleaned it with cotton bud as advised. Now sitting here oiled up and scratched but happy. engine started etc so will have to wait and see if stalls again. I plan to check oil filter next.
I live in Berkshire, near to Thatcham. 10 miles from Reading, 6ish from Newbury.
Veg_Ian
That's great news. Saves me a job tonight. Back to the hedge trimming then
RobertandMarnie
Hello helpers.
Bongo going well except for still stalling. I think it is linked to gears. when I slow down from a speed of 50 or 60 mph the gears don 't seem to change down quick enough and the engine goes into a stall. I have stopped it a couple of time by slipping into neutral and gunning the engine, but it is a skill thing so I do miss it.
How do I fix this?
--increase my idle speed? (seems to sit at 750 or so when engine first starts)
-- tinker (?) with the gear box somehow?
How do I fix this?
Could it be to do with the throttle position sensor (TPS)? rings a vague bell.
- The Great Pretender
Ok, I have used my psychic ability to contact your Bongo and it tells me it is short of breath.RobertandMarnie wrote:Hello helpers.
Bo ngo going well except for still stalling. I think it is linked to gears. when I slow down from a speed of 50 or 60 mph the gears don 't seem to change down quick enough and the engine goes into a stall. I have stopped it a couple of time by slipping into neutral and gunning the engine, but it is a skill thing so I do miss it.
How do I fix this?
To infinity and beyond
RobertandMarnie
Short of breath sounds right but bit difficult for me to fix.
Anyway, Throttle position sensor sounds like something I could maybe have a 'play' with.
