pcv valve
flyingdoc
pcv valve
hi,does anyone know if there is a pcv valve on the bongo,if so where is it located? + do they have o2 sensors.
Re: pcv valve
Petrol or diesel?
Re: pcv valve
Whats a pcv valve scanner
Re: pcv valve
See http://en.wikipedia.org/wiki/PCV_valvecheffy34 wrote:Whats a pcv valve scanner
Re: pcv valve
I didn't ask the question but I suspect as John's found it's a Positive Crankcase Ventilation valve.
But not sure about diesels (esp turbos) as they don't have manifold vacuum to do the "Positive Ventilation" bit.
I know petrols have to have them and they use the manifold vacuum to do the "Positive Ventilation".The Positive Crankcase Ventilation valve, or PCV valve, is a one-way valve that ensures continual evacuation of gases from inside a gasoline internal combustion engine's crankcase.
- dandywarhol
Re: pcv valve
........but they do have a vacuum pump.....
There must be some form of crankcase breathing system otherwise the oil seals would pop - I'll have a squint at lushprojects pages sometime.
Re: pcv valve
francophile1947 wrote:See http://en.wikipedia.org/wiki/PCV_valvecheffy34 wrote:Whats a pcv valve scanner
Thanks francophile
Re: pcv valve
I've never seen a diesel vacuum pump that connects to any sort of PCV valve and I don't think I'd like to see one that has been connected to one and sucking on all that goo for any length of time.dandywarhol wrote:........but they do have a vacuum pump.....There must be some form of crankcase breathing system otherwise the oil seals would pop - I'll have a squint at lushprojects pages sometime.
The crankcase has to have a breather that's obvious, but I'm not sure it vents to the inlet system anywhere or how.
