I've noticed that the 'concertina' boots covering my front suspension dampers are torn, exposing the shiny damper piston rods underneath - no doubt leaving them exposed will hasten their demise
Is it wishful thinking, or could replacing them (if replacements can be found...) be as simple as partially jacking up the front end, removing the single top nut which secures the damper top (from under the bonnet), pushing the damper piston back down into the shock and squeezing a replacement boot through the spring coils and over the damper???!!
Failing that, how much are new shocks going to cost me in a year's time...?
Thanks.
