hi does anyone out there know where the door switch is for the interior/strip light is?
i can switch the light on and off but nothing on the door.
interior lamp switch
simon638
MountainGoat
Re: interior lamp switch
If you mean the large strip light on the ceiling there is no door switch. The switch on this light has two or three setting one of which will make it go off when the sliding door is closed.
heatherpetch
ours has a spring loaded switch
open sliding door feel down r h side near runner
Huge thing on rear part of door frame, just below runner - you can't miss it
simon638
thankyou for that,but how does the light know the door is closed. i'm guessing its not "bongo-magic"MountainGoat wrote:If you mean the large strip light on the ceiling there is no door switch. The switch on this light has two or three setting one of which will make it go off when the sliding door is closed.
simon638
thanks guys, never seen that before!(had bongo 5 years)
off to the opticians first thing monday.
heatherpetch
just set light switch to middle position
simon638
have done and it now works,as i've taken off the switch cleaned contacts,applied wd40,put it all back together.heatherpetch wrote:just set light switch to middle position
