1 litre of blue winter windscreen wash (instead of blue water/antifreeze mix) into header tank today
Possible consequenses?????
H
Well,Harry wrote: There is no overheating that I can tell from the insensitive temp guage but there were some interesting 'smelly' bubbles oozing from the header tank overflow. The coolant level hasn't dropped significantly (the coolant alarm says it is ok).
H![]()
lizard wrote:
This is the o/s coolant pipe from the rad (top) hose to the engine hose. There was a hole at both ends, but was only leaking from the front. As the holes are at the bottom of the tube they can only be seen from underneath the vehicle and with hoses removed.
I had silicone hoses fitted in Feb this year, all was well untill I had a leak from the front hose/coolant pipe. Well worth checking.
All the best![]()
