cigarette lighter
susan
cigarette lighter
Does anyone know how i can get my lighter out off the socket as it seems to of got stuck
technophobe
- Tribal Elder
Re: cigarette lighter
Search ebay for 'Bongo pliers'. Sorry - couldn't resist it! Can't think what sensible advice to give except try this and try that. Ultimately, drill a small hole in the middle and screw in a self tapper so you can pull on it.
WD40technophobe wrote:Probably rust. WD40.
disconnect the termnials behind & see if you can remove the whole assembly, i think it's 2 squeeze in type clips behind the panel that hold it in, so it may not work with the lighter stuck in. can you rotate the lighter in the socket?, if the socket turns with it grip it from behind, it may free it up.
Front or rear , Front is a pain, can't imagine it with the lighter stuck in
I hate fiddley things, i do fiddley at work
Take it out by pushing, pinching and twisting from behind
then bin it and put an after market one in, cost me £4 i think, not orig but works and doesn't blow the fuse when i need to use it
mine got stuck once and it kinda, kept blowing the fuse after, don't think it was even orig lighter to socket if ya get me
My back one is goin on the list on the basis it likes to work when it feels like it
and i can have one i can find in the dark
reckon mine was owned by a smoker prev
PS
leave out the wd40
leave out the wd40
