Does this still happen or was it colder during the sixties and seventies
Global warming maybe
It doesn't freeze it "waxes" and that is now pretty much a thing of the past as diesel is now of a much higher quality than itb used to be and contains an anti-waxing additive in the "winter" grade sold in the winter months.pilajake wrote:Whilst growing up during the sixties and seventies, I remember TV images of lorry drivers being parked up along motorways with fires under their fuel tanksto defrost their fuel .
Does this still happen or was it colder during the sixties and seventiesor is it due to
So i am led to believe that "Winter" Diesel is different to "Summer" diesel and you get less Mpg during the cold periodscanner wrote:It doesn't freeze it "waxes" and that is now pretty much a thing of the past as diesel is now of a much higher quality than itb used to be and contains an anti-waxing additive in the "winter" grade sold in the winter months.pilajake wrote:Whilst growing up during the sixties and seventies, I remember TV images of lorry drivers being parked up along motorways with fires under their fuel tanksto defrost their fuel .
It is rumoured that the addition of this can lead to lower MPG, as it lowers the energy value of the fuel. but I can't find any definitive answer anywhere.
Under no circumstances should a naked flame be used on any part of the fuel
system or fuel tank. NEVER ADD PETROL TO THE FUEL. The addition of petrol
could be extremely dangerous and it is also unlikely that it will dissolve wax.
In areas of New Zealand where the weather is very cold for long periods it
is advantageous to use Shell Thermol (50% mixture of diesel and kerosine)
as a temporary diesel engine fuel. Shell Thermol will provide cold flow
protection down to minus 30°C. However, care must be taken with the use of
Shell Thermol in warmer weather, as it does not provide the lubricity to
pumps and injectors that diesel fuel provides. To achieve this lubricity 1%
volume of clean lubricating oil can be added to Shell Thermol. Check with
the equipment manufacturer before using Thermol in your engine or
machinery.
I think the blood in my hands froze today!!Does diesel freeze?
Wife's just phoning for an ambulance. Tried to read it sideways and my neck cricked and won't move. I'm suing Shell. Where's FatCatLawyerscanner wrote:Found what I was looking for.................
http://www.shell.com/static/nz-en/downl ... winter.pdf
mikeonb4c wrote:Wife's just phoning for an ambulance. Tried to read it sideways and my neck cricked and won't move. I'm suing Shell. Where's FatCatLawyerscanner wrote:Found what I was looking for.................
http://www.shell.com/static/nz-en/downl ... winter.pdf![]()
C'mon scanner, I'm Irishscanner wrote:mikeonb4c wrote:Wife's just phoning for an ambulance. Tried to read it sideways and my neck cricked and won't move. I'm suing Shell. Where's FatCatLawyerscanner wrote:Found what I was looking for.................
If you right click for the menu there is a "Rotate Clockwise" button, click it once and it rotates 90 degrees.
Not necessarily - he may have just thought he could save a few p/litre by stocking up in the summer when diesel doesn't have the anti-wax additive in it.karena wrote:one of our farmers said his diesel had waxed in his tank yesterday he was about to stick petrol in it - mind you knowing our farmers, the diesel will have been there for yonks and is probably some sort of knock off / home made/illegal version of diesel.
Only a cynic would think that Shell Thermol would cost more than petrol (if you can locate it)scanner wrote:Found what I was looking for.................
From Shell New Zealand.
Which concludes with this
machinery.
