Checked the Bongo just before we went on holiday (start of December, before the cold snap) to find that there was no coolant in the plastic expansion tank. EMPTY.
Still, continued on hols, and only got back last weekend. Had a look this morning (hoping I had imagined the whole event) and no, it's still empty.
So I'm thinking, either:
1. Previous owner had the wrong antifreeze concentration in there... so it froze, expanded, and probably killed the radiator, and lost the fluid.
2. A rubber hose finally died (while the Bongo was parked up??) and fluid dumped (my driveway is gravel, so I wouldn't really notice any leak while parked).
Or
3. Something else that I haven't thought of, but you guys might have....
In addition, now that I've had a good look in the expansion tank, it does look a little red/brown in there.
Not sure what to do first. Refilling with coolant looks like a fairly fiddly process from the factsheet (and a pointless waste of cash if its all going to end up on the driveway). Don't want to test the systems integrity with water as if any does remain in there, it'll probably freeze and cause more problems.
There's a Bongo Specialist about 2 miles away (ADS, South Liberty Lane, South Bristol - anyone tried them?) so I'm very tempted to just let them have it... although I can't drive it 2 miles dry, can I?
Be nice to know what I'm dealing with first, I might do the job myself, especially if it's expensive.
Any sugestions on where to start? Don't want to make a bad situation worse, but want the Bongo back on it's feet by Spring!
Thanks in advance
