FRONT FOGLAMPS
brian-willoughby
FRONT FOGLAMPS
Post by brian-willoughby » Thu Mar 05, 2009 7:58 pm
I have just acquired a very nice Bongo.
It was imported with Front Fog lamps fitted, but no switch fitted on the dashboard.
Can any fellow owner tell me how to get them working?
Also what does the T.V Screen fitted above the radio do?
Reards Brian and Joan.
waycar8
Re: FRONT FOGLAMPS
Post by waycar8 » Thu Mar 05, 2009 8:06 pm
hi Brian, welcome to the forum mate, is the screen fitted in Japan or here on arrival?, if its one from Japan which is probably the case, its no good, the tvs in Japan are different to ours so they are worthless. as for the front fog light switch?.........is there a hole in the dash where a switch was?
aitch
Location: in a place far, far away, well Somerset for now!!!
Re: FRONT FOGLAMPS
Post by aitch » Thu Mar 05, 2009 8:27 pm
Ditto above with regard to the screen but the fog/driving lights is a nother matter try and follow the wireing to trace where it is going and you might find it behind the dash and just needs a switch - mine is fitted with "set in the bumper" lights but I cannot trace the wire so if you have success let me know and good luck.
waycar8
Re: FRONT FOGLAMPS
Post by waycar8 » Thu Mar 05, 2009 8:32 pm
Have you tried to see if they come on with the high beam?, i have heard of a couple that have had them wired up to the main beam :| , a bit pointless imo but hey each to their own
Re: FRONT FOGLAMPS
Post by francophile1947 » Thu Mar 05, 2009 8:36 pm
Mine came on when I switched any lights on :?
aitch
Re: FRONT FOGLAMPS
Post by aitch » Thu Mar 05, 2009 10:30 pm
Lucky you John have been playing with my lights for two years and I have yet to get them on at all!!!!!!!!!!!!!!!!
Re: FRONT FOGLAMPS
Post by francophile1947 » Thu Mar 05, 2009 10:34 pm
aitch wrote:Lucky you John have been playing with my lights for two years and I have yet to get them on at all!!!!!!!!!!!!!!!!
I disconnected them anyway, just in case an officer decided to nick me for illegal use - must get round to rewiring them sometime :lol: :lol:
Re: FRONT FOGLAMPS
Post by Doone » Fri Mar 06, 2009 5:14 pm
In this link, they discuss the option of wiring in a switch for the front fogs. There's a lot of additional info, so it should help.
technophobe
Re: FRONT FOGLAMPS
Post by technophobe » Fri Mar 06, 2009 7:50 pm
I've got a switch for each pair. :D
Richard & Jo
dandywarhol
Re: FRONT FOGLAMPS
Post by dandywarhol » Fri Mar 06, 2009 10:58 pm
Would some kind soul wiggle out their switch and see if it has 2 round black bulb holders in it - about 4m diameter on the left side.....................Thanks :D
maxheadroom
Re: FRONT FOGLAMPS
Post by maxheadroom » Fri Mar 06, 2009 11:20 pm
Standard fitted one only has one bulb. :D
Keep the Faith
dandywarhol
Re: FRONT FOGLAMPS
Post by dandywarhol » Sat Mar 07, 2009 1:29 am
maxheadroom wrote:Standard fitted one only has one bulb. :D
Thanks max - and where does the standard front foglamp warning light live?
I picked up a 2 bulb Mazda switch which I thought would be easy peasy fit but its got a weird circuitry involving a diode and seems to earth the warning light (in the switch) via the relay coil and earth :? #-o
maxheadroom
Re: FRONT FOGLAMPS
Post by maxheadroom » Sat Mar 07, 2009 10:16 am
I too have a similar switch and have never managed to get it to work. Can't help with the wire at the moment but if I find out I will post. :D
Keep the Faith
