SPEEDOMETER- CONVERSION
gina
Post by gina » Thu Mar 12, 2009 9:18 pm
Hi just replaced the speedometer conversion, should we have taken off the old Kilometre disc as we now have no lights behind on that dial?
Gina and James
Re: SPEEDOMETER- CONVERSION
Post by Doone » Thu Mar 12, 2009 9:29 pm
Do you mean you've fitted a speedo face over the old one, without removing it? I think a couple of people may done this, but it's better if you take the old speedo face off.
gina
Post by gina » Thu Mar 12, 2009 9:53 pm
MMM yes fitted it over the old one.......should we have taken it off?
Jolly Rogers
Post by Jolly Rogers » Thu Mar 12, 2009 10:26 pm
Yeah you need to take the old one off. You will need to take off the needle. Be gentle.
gina
Post by gina » Thu Mar 12, 2009 10:38 pm
opps never took off the needle to hard.... cut the dial....... opps
Triple/R
Post by Triple/R » Thu Mar 12, 2009 10:50 pm
gina wrote:MMM yes fitted it over the old one.......should we have taken it off?
I did that with my dial---put new one on top of old--stops light getting through--youve still got to take the old one off--the needle has got to come off--use 2 teaspoons for leaverage resting them on the 2 small screws lever gently & watch the balance weights when they drop out --remove original dial & put new one on only--before replacing needle & weights switch ignition on then replace needle at zero--this worked for me but don't work for everybody.
Regards Ray & Christine
Post by teenmal » Fri Mar 13, 2009 12:29 pm
gina wrote:opps never took off the needle to hard.... cut the dial....... opps
Hi Gina,when I replaced the dial face,I removed the old face,cut the new face from 6 oclock to the centre of the dial.
I then eased the new cut face over the pointer,fitted the two screws and put everything back together.
That was about a year ago and its working fine.
Cheers Malc..
Post by bigdaddycain » Fri Mar 13, 2009 1:49 pm
:? Why does the needle have to be removed? :?
Post by teenmal » Fri Mar 13, 2009 2:02 pm
bigdaddycain wrote::? Why does the needle have to be removed? :?
Depends on the size of your (dial) hole. :wink: :wink:
gina
Post by gina » Fri Mar 13, 2009 5:58 pm
Thanks for all your help....Gina and James
vanvliet
Post by vanvliet » Fri Mar 13, 2009 6:31 pm
See other threads about replacing the Bongo speedo with a proper MPH one from a UK 626
Origo bio stove - no Bongo!
Manny
Post by Manny » Fri Mar 13, 2009 6:46 pm
I got a Mazda 626 speedo from a breakers. This has the advantage that the odometer will also be in miles.
Manny
A Bongo by any other name would still drive as sweet.
