Need help tonight.
hatris
Need help tonight.
Post by hatris » Thu Mar 26, 2009 11:42 pm
We are setting off for tough Northerners tomorrow early, so was hoping to get some advice tonight. Had a long drive last week coming home from Mablethorpe, towards the end of the drive the "4W ABS" light came on but then it went out again later. We have just taken the bongo to fuel up for this weeks trip and it is coming on again. Is it anything serious or unsafe to drive to Craster tomorrow. Thanks for any help Trish
brorabongo
Re: Need help tonight.
Post by brorabongo » Thu Mar 26, 2009 11:53 pm
Check this topic out, one of a few......
http://www.igmaynard.co.uk/bongo/forum/ ... +abs+light
Ayway have a great time at the tough Northerners.
ボンゴの激怒 pictures
dobby
Post by dobby » Thu Mar 26, 2009 11:54 pm
dobby
brorabongo wrote:Check this topic out, one of a few......
SNAP!
brorabongo
Post by brorabongo » Thu Mar 26, 2009 11:56 pm
dobby wrote: SNAP!
:lol: Aye, you've gotta be quick on here, eh!!
ボンゴの激怒 pictures
daveblueozzie
Post by daveblueozzie » Thu Mar 26, 2009 11:58 pm
I remember waycar mentioning something about the abs light coming on when he drove through water or heavy rain. dunno if that's what you have done.
i also remember him saying turning off the ignition and then turning it back on resets it. if that does not work it might be a sensor fault.
Lost without my Bongo.
MountainGoat
Post by MountainGoat » Thu Mar 26, 2009 11:59 pm
The Bongo has an on board computer I think :-k Never had problems with my Bongo but I have had problems with the warning light on my Jeep Cherokee. After trawling the Jeep websites on the internet I found a blog that recommended disconecting the starter battery for 15 mins to let the computer re-boot itself. It worked, no problems since. Perhaps someone could confirm that this will work with a Bongo.
See you tomorrow.
Tony
Bit slow tonight ](*,)
hatris
Post by hatris » Fri Mar 27, 2009 12:51 am
Thanks all for your help. We will get it sorted when we get home. Safe journey to all going, hope to see you there. Just love the way you can get help and peace of mind from you guys. Thanks Trish
Post by Muzorewa » Fri Mar 27, 2009 8:06 am
Ours came on after we had been 'experimenting' with the 4WD on sheet ice on a carpark. Switching the engine off and back on again sorted it. I presumed the ABS system had got confused due to the varying traction it was encountering. :wink:
waycar8
Post by waycar8 » Fri Mar 27, 2009 6:23 pm
daveblueozzie wrote:I remember waycar mentioning something about the abs light coming on when he drove through water or heavy rain. dunno if that's what you have done.
Thats spot on my little lancashire smurf :wink:
Yes i drove through a puddle (ford) :lol: and my abs light camer on, drove a bit and it didnt go off :shock: , pulled over turned off ignition had a look under the bongo, dripping water everywhere so i thought i must have fried a sensor in the hub, got back in and started up the bongo and it went out, carried on home, and hit a wall of heavy rain, came on again ignorred it and carried on.
Noticed the brakes wernt as effective but still worked, got home read my little manual and it does say that if it comes on turn off ignition then back on and it will reset, its not dangerous as your brakes will switch from abs mode to normal (remember the days when cars didnt have abs :lol: i remember when i bought my vectra (18 months old at the time, the car not me :| ) it had abs, pulled out of the forcourt drove down the hill pressed the brakes and nearly headbutted the steering wheel, big difference when youve just drove onto a forcourt in a L reg suzuki vitara without abs :lol:
well enough of the old times, Trish dont worry about your brakes they will still work but not as abs :wink: , when you get home just check make sure you haven a loose wire anywhere, also check in the front wheel arches, you will see a black wire going into the bonnet area (above the brake pipe) they have a joint in there :!: cant remember if its in the bonnet area (which i do think it is), just make sure they havet come appart :wink:
Enjoy you meet Trish and Harry
hatris
Post by hatris » Thu Apr 02, 2009 2:47 pm
Thanks Wayne sorry but I didn't get to read this till we got home.
We think the brakes are still working as normal. We have noticed the light comes on and then goes out with all the other lights after ignition. The light is only coming on and staying on if we switch on the car headlights. Will this just be a crossed wire do you think?
waycar8
Post by waycar8 » Thu Apr 02, 2009 7:12 pm
possibly, have you had any electrics done lately?, or had the dash (clocks fascia) out?, maybe knocked a wire or even a bad earth somewhere.
other than that i couldnt imagine why it comes on when you turn the lights on :?
steviebongo
Post by steviebongo » Thu Apr 02, 2009 7:39 pm
hi there ure brakes will work as normal ones do only difference is that if u press to hard they will lock up ,on the fault the light comes on when u use electrics it could be a battery voltage drop?poss battery or charging concern.
cheers stevie
hatris
Post by hatris » Thu Apr 02, 2009 7:46 pm
Thanks mate that actually makes a lot of sense. No recent electrics done but we noticed the charge dropped quite quick at Craster. Cheers will look into it.
steviebongo
Post by steviebongo » Thu Apr 02, 2009 7:58 pm
no probs ,good luck and seen ure bongo at craster I like the color.
cheers stevie
