rear wheel bearing
dennis2719
rear wheel bearing
hi has anyone removed rear wheel bearing and spacer ,I have removed half shaft but cannot see how bearing and spacer can be removed other than taking a disc cutter to them.
Re: rear wheel bearing
Welcome to the madhouse
Sorry, I've no idea but somebody should be along who has done it.
Please read http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=29471 - local help is often available, if we know where you are
This may help http://www.lushprojects.com/bongopartsm ... mgno=.html
- dandywarhol
You'll probably need to split the collar with a chisel to get the bearing off - I haven't done a Bongo one but done similar RWD bearings on cars many moons ago.
