My freda's making a ticking/clinking noise from the left front area.
At first it started as a single clink when you pulled away..now its a near constant noise all the time. Its not engine related. I'm thinking cv joint?...but they were changed by the last owner & the noise doesn't get any worse full lock in a circle. Then I thought wheel bearing..but theres no play or sound when you spin the wheels. I've checked the prop shaft as best as i could..the joints seem o.k. I'm now wondering if it could be the diff?
Any ideas would be greatly appreaciated.
Spence
