Also the fusible link connected to the glow plug control and the battery has gone as well. So I am now jumping in the deep end as to learning about diesel engines!2) Took me ages!!!! Having recently changed my glow plugs for some nice new NGK's i focused my attention there to see if i had made a boo boo..... Well, it turns out that the top end of the NGK's were a little shorter than the Jap ones. The inside bit is the same and they work fine but due to the top measurement the glow plug rail was rubbing on the metal piping underneath it. It took a couple of weeks but the rubber on the rail eventually rubbed through and hey presto, earthed out the rail causing (1) to melt!!!
My questions are
1) I would be worried about bending those fuel pipes as they are short and I might snap them, can I adjust the glow plug rail a little higher by putting some nuts or washers under it where it is attached to glow plugs?
2) Their don't seem to be any fusible links in this country and will take 10 days to order some what alternative can I use and if a wired fuse what amperage should it be?
Many thanks for all replies.
Martin
