help with fuse box
- peanutcrusher
- Tribal Elder
help with fuse box
can anyone send me a photo of their fuse box, if anyone can supply and diagram listing the fuses it would really help
and if anyone can help with which wires go where when installing a split charger.
Bongo now work later !!!
- daveblueozzie
Re: help with fuse box
1 Cabin (10a)
2 Hazard Lights (10a)
3 Brake Lights (15a)
4 Central Locking (30a)
5 Horn (10a) Rear lights (10a)
6 Blinds:- passenger side (15a)
7 Blinds:- driver side (15a)
8 Cigar lighters, mirrors, radio (15a)
9 Engine Management System (15a)
10 Dashboard (15a)
11 Indicators (10a)
12 AFT Roof (30a) or Sun Roof (20a)
13 Rear wipers & washers (10a)
14 Electric windows (30a)
15 Front wipers and washers (20a)
16 Aircon (10a)
17 Sliding Door (15a)
18 Glow plugs (10a) Headlamps (20a)
19 Additional equipment Additional equipment
20 Rear demister (30a) Additional equipment
(Spaces on bottom row used for dipped beam-Xenon option)
10 Dashboard (15a)
11 Indicators (10a)
16 Aircon (10a)
Last edited by daveblueozzie on Thu Apr 30, 2009 10:00 pm, edited 1 time in total.
Lost without my Bongo.
steviebongo
- Tribal Elder
if u got a willinton kit he emails u pics ,best kit oot there and so is the backup.
cheers stevie
cheers stevie
- peanutcrusher
- Tribal Elder
do i need to disconnect the battery to replace fuse number 8 or will it be OK to just go ahead and do it.
Just change it. Fuse diagram is in the factsheets in the members area if you need it.
- daveblueozzie
you don't normally disconnect a battery just to change a fuse. (well i don't )peanutcrusher wrote:do i need to disconnect the battery to replace fuse number 8 or will it be OK to just go ahead and do it.
- peanutcrusher
- Tribal Elder
i need to pull out the split charge lead that in the slot to replace the fuse as the second battery is not in the system yet and the radio stops every time i slow down.
- daveblueozzie
what is the split charge connected to ?peanutcrusher wrote:i need to pull out the split charge lead that in the slot to replace the fuse as the second battery is not in the system yet and the radio stops every time i slow down.
dont you have a second battery.if not why have a split charge.
the radio stops when you slow down
- peanutcrusher
- Tribal Elder
the battery is next to me in my front room charging up. I've just had the split charger installed today but they did not have my battery to put in. so the wire for the internal light has not been plugged in yet only the one for the radio.
I'm not to sure if my second battery is holding a charge so i saw looking to bypass the system for now if i remove the wire from the radio slot and replace the fuse i take it everything will work fine.
I printed the fuse diagram out and laminated it and keep it in the glove compartment (in case of emergency)LOL
That'll Be The Day.........
'99 Silver V6 Moonfleet Conversion
- daveblueozzie
OK now i understand, yes isolate and tape the wire you take out of the fuse, just in case you forget and connect the second battery. it should then work with the fuse fitted.peanutcrusher wrote:the battery is next to me in my front room charging up. I've just had the split charger installed today but they did not have my battery to put in. so the wire for the internal light has not been plugged in yet only the one for the radio.
Last edited by daveblueozzie on Thu Apr 30, 2009 10:49 pm, edited 1 time in total.
- peanutcrusher
- Tribal Elder
- daveblueozzie
excellent idea.buddyh42 wrote:I printed the fuse diagram out and laminated it and keep it in the glove compartment (in case of emergency)LOL
I keep mine folded up in the lid over the fuse box
