Overheating Issue
Posted: Sun May 03, 2009 9:31 am
Hi all,
Just passed my first year with the Bongo, so it went in for MOT (nothing major: rear oil seals leaking onto rear discs, and rear anti-roll bushes needed replacing; garage replaced with parts I ordered from club shop, replaced brake pads also).
Anyway, KM wise, it was time to change the cambelt, so I had him do that and a full service whilst it was off the road, to get me ready for the summer, again I sourced the parts for this from club store, garage did the work, and Bongo was returned to me last Wednesday, £280 for the MOT and labour, not too bad I thought.
Don't really use the car during the week, made just one 2 min journey to pick the wife up from the station with heavy bags. Then, around rolled the, now somewhat ruined Bank Holiday weekend.
Saturday lunch time, and we were heading just 10 or so miles away to Knebworth House (garden festival the wife was keen on), got into the Bongo and, 1.2 miles from home, at the round-about which joins the motorway, I glanced down to see my temp gauge higher than the running temp norm (normally takes about 4-5 miles to get up to temp, with the last 3 or so miles being on the motorway), deciding against joining the m-way at this point, i turned off the roundabout and drove to a layby (total distance from home 2 miles) by which point the temp guage was almost in the high end.
Stopped, turned off, popped bonnet and chairs up and checked hoses.
No heat in the header tank, radiator (tho the fan was going), or pipes running to the front, not much heat in the pipes under the seats, some slight warmth in the smaller pipes under the passenger seat.
a LOT of pressure in the system, however, some water being forced out of the little pipe on the header tank, and a test half-turn on the header tank let out a fair amount of pressure and a little (cold) water. Didn't want to undo it and risk losing coolant at this point so sealed her up, switched her off and let her cool down.
After about 30 mins, drove the 2 miles back home again, with one stop for about 10 mins in a layby, again, needle running in the high end. Not a happy boy.
Grabbed some builders rubber gloves, a towel and a jug to try to catch what i could, and opened the header tank, again masses of pressure, and a significant amount of coolant ejected itself from the car, firstly cold/cool, eventually warm and f-ing hot. Figure I lost about 3 pints, managed to catch about 1.
Rinsed the spillage away, then started her up with the expansion tank cap off, significant increase in steam leaving expansion tank with cap off when running, checking hoses, most of those under the seats now how, top hose coming into rad now hot, bottom hose leaving rad not yet.
At this point, determined not to let a broken car ruin the nice sunny day, I closed it all up, shrugged shoulders, and went off to examine the methods of public transport to get us to see the plants. We eventually got there at about 3pm after a 15 min train journey and 5 min cab ride (plan was to get there for 1330 in the car, oh well) and had a nice afternoon, although getting the £90 of plants the wife decided to buy home was quite a mission!
So - suggestions, please, for what is likely to be the problem? Almost impossible, to my mind, not to have been something the garage messed up (had a year of trouble free motoring till now!). I'm thinking this is likely to be no flow of water round the system, either due to an airlock, or water-pump not turning? Anything which they'd need to do to change a cambelt likely to impact that? I'd have thought not really.
I'll probably have an hour or so later today to get out there and have a look, i'll check the water pump actually has a belt on it, and may do what I can to bleed and top-up the cooling system, see if i can get it running normally for use this afternoon (was supposed to be a DIY day in the garden), and tomorrow (trip to Cambridge was planned; may once again be forced onto the trains, not a tragedy in this instance, cambridge quite easy from here).
Anything else I should check? Concern, i guess, is around head & head-gasket, if water has been boiling up in there and only moving through convection?
I suspect it'll be back to the garage on Tuesday morning for a grumble!
Thanks,
Gav.
Thanks,
Gav.
