wet afT
- peanutcrusher
- Tribal Elder
wet afT
at the front of the aft where the wall of the aft screws into the roof there is what looks like some sort of foam seal I have found water in this area do you think its a leak as the form seems wet as well as the surrounding area also I found that the switch to cancel the roof close stop was dripping wet. could this be condensation. please help
Bongo now work later !!!
- mikexgough
Re: wet afT
I have had condensation there before, I generally wipe the excess off with a microfibre cloth and also unzip the AFT to blow it through - also I tend to sleep with the small "smiley" vent undone to reduce condensation - I'm sure others will have their opinions and how to's....
