Left Radiator Expansion Cap Off
I did something really stupid last week. I topped my radiator expansion tank up, and left the expansion tank cap on the side.
I drove 80 miles going between 50-65 and after coming to a hill I put my foot down to overtake a lorry. Shortly after overtaking I noticed steam coming from the bonet, looked at the temperature gauge and it was all the way right. I pulled over immediately, switched off my engine, but kept the ignition so the radiator fans were going. I opened the bonet to find the radiator cap on the side still but water everywhere. I keep 2 1 litre bottles of anti-freeze, so put those in the expansion tank immediately, then used water from my camping bottle to slowly pour water into the expansion tank. I let the engine cool down. I then proceeded to start the engine, which it did first time. I left it 5 minutes to check the temperature didn't rise, and it seemed okay.
I drove it the remaining 30 miles of my journey without any troubles and checked it again. I left the van a few hours a proceeded to fill up the expansion tank again, as it must have had a air block. I then started the van and kept filling the expansion tank up till the air had had completely gone from the system. 2 days later I then drove 150 miles and the expansion tank was still full when I arrived at my destination.
My question is, because the radiator cap was off, and the water was free to boil at 100 degrees rather than being under pressure, would the engine have got hot enough to boil the oil as well?
Could there be any other damage to the engine which I am not aware about, even though it is running perfectly fine now?
- stilldesperate
- Tribal Elder
Re: Left Radiator Expansion Cap Off
Have you bled the coolant with the pipe under the passenger seat? (Details on factsheets in members area)
Your oil can take a lot of abuse, I would be more worried about the cylinder head, but from what you've described, it sounds as if you've got away with it!
Wouldn't worry too much about the oil, more about possible damage to the head. sounds like you may be ok
, but I'd make sure it's bled properly as per the instructions in the members area factsheets.
Keep an eye on the levels & think seriously about getting a low coolant alarm, TM2 or Mason alarm fitted, would have told you long before the useless temp gauge moved or you noticed any steam.
Check thorugh the old threads on overheating etc - a plethora of info there to scare you
Damn too slow SD beat me to it
- stilldesperate
- Tribal Elder
[quote="missfixit70"]Wouldn't worry too much about the oil, more about possible damage to the head. sounds like you may be ok
quote]
Wish I'd thought of that!
quote]
- dandywarhol
Is there another problem which necessitated the tank to be topped up in the first place?
- stilldesperate
- Tribal Elder
You're good, Dandy - real good! (In best Bobby De Niro voice)dandywarhol wrote:Is there another problem which necessitated the tank to be topped up in the first place?
Low coolant alarm would be the best to have fitted as you'd have got a warning before the level dropped below the min recommended in the header tank and thus have avoided an airlock (provided you had some spare water with you to top up with!). You now need to check there is no airlock in the system I reckon and - for the rest - fingers crossed the engine is OK.
So No.1 priority is to fit an LCA
Thanks all for your advice! Looks like I was lucky this time!
I am gonna get a coolant alarm fitted asap. Because I am a novice, i am going to take it to ADS in Bristol to look it over. Because I am topping the fluids up every couple of months (which I thought was normal for Bongos believe it or not), they believe it could be either the pump leaking or one of the pipes running along the engine which is corroding.
Cheers!
Cheers!
Some spare WHAT?mikeonb4c wrote:(provided you had some spare water with you to top up with!).
Your spelling Mike
Dandywarhol IS good, but I thought for a moment you hadn't taken him seriously. Glad you are in fact on the ballpaulandyt wrote:Thanks all for your advice! Looks like I was lucky this time!
Cheers!
I knew someone would jump in with that, and it had to be youscanner wrote:Some spare WHAT?mikeonb4c wrote:(provided you had some spare water with you to top up with!).![]()
Your spelling Mikethe stuff you need to top up with is coolant.
The reason I said it was to relax the guy. You may not have 50/50 coolant mix with you but for the very small amount of dilution that would occur it would suffice just to have some water with you. But obviously, regular topping up should be with 50/50 coolant mix
- stilldesperate
- Tribal Elder
No, I was being serious, I was distracted by the possible engine damage, and didn't think to question why the coolant needed topping up in the first placeRon Miel wrote: Dandywarhol IS good, but I thought for a moment you hadn't taken him seriously. Glad you are in fact on the ballThere's always a reason.
It's a very good point, that there's always a reason!
SD
Thanks guys! Really appreciate the feedback!
I'll let ya know how it gets on!
P
P
And I was so distracted by it, I had got my wires well and truly crossedstilldesperate wrote:No, I was being serious, I was distracted by the possible engine damage, and didn't think to question why the coolant needed topping up in the first placeRon Miel wrote: Dandywarhol IS good, but I thought for a moment you hadn't taken him seriously. Glad you are in fact on the ballThere's always a reason.
SD
- haydn callow
ADS in Bristol keep some Low Coolant Alarms in stock....first class garage,
